Eero 6
Gateman148
Message 3 of 3
Just upgraded from Fibre 65 to 150 and received Eero 6 today.
Problem 1.    My previous TalkTalk hub has a phone socket and four Ethernet sockets plus a WPS Button. Connecting my landline phone was therefore very easy but the Eero does not appear to support this as it only has two ethernet sockets.
Problem 2.  I can't get my Mac to connect wirelessly to my HP printer now I've installed the Eero 6 whereas it was a simple matter with the TalkTalk hub by connecting it via the WPS button.
I have spent ages trying to sort this and cannot get through to the TalkTalk helpline.
Can anyone provide an explanation to my problems?
Thank you.
Message 1 of 3
I agree with @Michelle-TalkTalk you should have also been provided with the Grandstream ATA for the Digital Voice. To answer your other questions:-
  1. No enough Ethernet ports. You can buy 5 port Gigabit data switches very cheaply online.
  2. The Eero does not support WPS at all. I do have a workaround if you still have your old router.
Message 2 of 3
Just to confirm, when you received the eero did you also receive a Grandstream Digital Voice Adapter, as this is how you would connect the phone?
What happens when you try to connect the printer?  - Problems connecting a device to eero - TalkTalk Help & Support
