Free switch to FTTP but cant upgrade
Strokkur
Message 9 of 9
We were switched to FTTP (Cityfibre) FoC but now can't upgrade the faster speeds due to a 'problem' between TalkTalk and Cityfibre. Call centre has been pretty vague about the issue. Is this a real thing and when will it be fixed?
8 REPLIES 8
Message 1 of 9
Its down to city fibre, im sure that they are aware of this and will be working towards a solution.
Message 2 of 9
Is there any actual move to fix this? It is a huge omission in the service and quite frankly tells me I should probably look at alternatives having been with TalkTalk for years.
Arne-TalkTalk
Message 3 of 9
No change I'm afraid regrades on City Fibre still require a cease and re-provide.
Message 4 of 9
Recently I have seen the same advice being given out, @Strokkur.
I'll re-escalate this thread for you, for staff to give you the latest on this.
Strokkur
Message 5 of 9
Has this situation changed at all? We are now 3 months later
Message 6 of 9
Sadly its days, it appears city fibre use different processes to openreach where the profile has to enabled manually, there is an ongoing discussion to try to simplify this.
Strokkur
Message 7 of 9
Thanks for responding.
Seems a bit of an amateurish service.
Is loss of service a few hours, a day, days?
Arne-TalkTalk
Message 8 of 9
Hi Strokkur
Regrades with city fibre can only be done by ceasing the service and reordering the higher speed , this will unfortunately mean a loss of service while the new order is processed.
Sorry.
