Full fibre dropping out regularly
Judders
Message 10 of 10
I have full fibre which, since its installation in December of last year, has been regularly dropping out. Since the end of January I have recorded the dropouts when I notice them. It Generally drops 3-4 times a day for a minute or two.
I am fairly certain this is a line problem and not a router/wifi issue. Each time the service drops out the router orange light comes on and flashes a bit before connection is re established. I have been unable to get to the ONT every time to see what the lights are doing on each drop out but have, on a couple of occasions, observed one of them (I don't recall which one) going off before coming back on and service re connecting.
I chose full fibre because I had been having this issue with my old copper line for years. Despite changing providers a couple of times and an extremely hard won visit by an open reach engineer to check the connections it could never be fixed. I finally upgraded but alas the problem persists.
Please could someone please advise how to go about getting this fixed?
Thank you
9 REPLIES 9
Message 1 of 10
Hi @Judders
That's great 🙂 If you do experience any further issues then please let us know.
I have also sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 10
Thank you, yes it’s all set up and I’m keeping an eye on it. Hopefully this will resolve it. Thanks for your help so far.
Message 3 of 10
Message 4 of 10
Hi Judders
Please let us know how the connection compares with this router.
Message 5 of 10
Thanks for the response. Yes I’ve got a Huawei router. See attached pic. And happy to try anything to rectify the issue so please send a replacement and we’ll give it a go.
thanks
Message 6 of 10
I'm sorry for the delay. I've run a test on the line which is clear, however I can see drops in connection. Are you currently using the Huawei Wifi Hub? I think we should send a replacement router for testing purposes, would this be ok?
Message 7 of 10
I'll escalate this back to TalkTalk for you.
Judders
Message 8 of 10
I’ve updated the info as requested.
Message 9 of 10
  • Name
  • Telephone number/Account number
  • Alternative contact number
