tv box
Muriel#75
Message 2 of 2
hello,
my new talk talk tv box looses signal and needs retuning every day. signal is good generally.
anyone experienced this problem ?
1 REPLY 1
Message 1 of 2
If you connect the aerial directly to your TV and check some channels, are they showing ok.  This will check the aerial signal to make sure this is ok.
