BBand speed fallen well below 21.5 Mb/s guaranteed speed
exBT2
Message 51 of 51
Hi, BB speed fallen to 15-16 Mb/s and there is a buzzing noise during conversation on my telephone line. The router has been reset and the line noise is present with a phone plugged into the internal master socket (with router disconnected)! The BB speed has been measured using ethernet connection, not wifi.
A on-line line test shows a fault present which could not be identified and a reference given - REP-13645566. I am now locked out of further tests.
Can you please tell me what happens next, do I have to wait for fault to be investigated? Or any other procedure? It's not clear from the test result info what follows.
Thank you,
Mike.
50 REPLIES 50
exBT2
Message 41 of 51
Debbie,  Openreach have cleared the line fault. The link speed is now just above the guarantee but the speed via ethernet connection is only 16 Mb/s and it used to be around 23-26 Mb/s. Does this mean that it will take the router a while to sync to a higher speed? Nothing has changed here apart from the line fault.
Thanks,
Mike.
Oh and the TT speed test shows 'poor'
Message 42 of 51
Thanks Debbie, for update, no sign of Openreach yet.
Message 43 of 51
Hi Mike
There are no updates from Openreach as yet. I will post back as soon as I have further information.
Message 44 of 51
Morning Mike
I've checked for an update and this fault is still with Openreach.
I will check on this again later this afternoon for any additional updates from Openreach.
Message 45 of 51
Hi Mike
Ahh no problem 🙂
I will keep you updated.
Message 46 of 51
Thank you so much, trouble shooting could not be much faster! 😁 will await BT engineers response and monitor this thread.
Best wishes,
Mike.
Message 47 of 51
Hi Mike
The same fault has been detected on the line tests so I have escalated this straight over to Openreach to be investigated by a line engineer (external investigation)
I will continue to monitor for updates and I will post back on this thread.
Thanks again.
exBT2
Message 48 of 51
Sorry, mis-read will disconnect phone too.
exBT2
Message 49 of 51
Thank you for speedy reply, I can remove the face plate and plug in just the phone in a couple of minutes if that's OK.
Message 50 of 51
Hi Mike
The line test is detecting a potential line fault. Just to confirm, is the phone connected directly at the test socket at the moment?
Would it be possible to remove everything from the line including the faceplate for 30 minutes so I can run another line test?
