Can't connect to VPN
DLT75
Message 7 of 7
Hello.  I can't connect to VPN.  I have checked my router and its version  SG4K100130.  My IT department says that PPTP is blocked.  Please can you advise.  I need to work.
Thank you
6 REPLIES 6
Message 1 of 7
Hi Debbie
I'm so glad to hear this.
I will feed this back, apologies for this.
If you do experience any further issues then please let us know.
DLT75
Message 2 of 7
It works.  Thank you so much.
Also, if you liase with Talktalk customer services team, perhaps they could be told its an easy fix and an engineer visit isn't necessary!
Message 3 of 7
Hi Debbie
The router firmware has now updated. Please can you retest and let us know how you get on.
Message 4 of 7
Hi Debbie
I will do this now, please can you keep the router switched on and I will post back here as soon as its been updated.
DLT75
Message 5 of 7
Yes please
Message 6 of 7
Hi Debbie
Apologies for this. I will need to make a change to your router firmware. Will it be ok if I do this now?
