Constant Lag Spikes and Disconnections
Ryan321
Message 5 of 5
Since 23rd June I suddenly get random extreme lag spikes and disconnections for no apparent reason on both wired and WiFi interent. I use my computer to play low-spec games on a wired connection and never download large content.
1. I have checked the router and it seems fine.
2. When the problems occur I am often the only one in the house and according to the TalkTalk WiFi Hub there are only a handful of devices connected.
3. My current download speed is 31.1 MB and the upload speed is a shocking 0.5MB.
4. There have been no changes to the way the internet has been used since the problems began.
I contacted TalkTalk twice on live chat and they said they would spend 20 minutes conducting a test, but I never receive a response from them concerning the results of these tests.
Is anyone able to assist me please?
4 REPLIES 4
Message 1 of 5
How are you getting on? Do you still need assistance with this?
Message 2 of 5
  • Name
  • Telephone number
  • Alternative contact number
Ryan321
Message 3 of 5
Hi Skynet,
Thank you for your response and all of your help. The white light is consistently on and the landline works. I kept trying the live chat system and got this message:
Line tests indicate there is a fault on your line and an Openreach Engineer is required to fix it.
It is believed the issue is outside of your property so the engineer should not need to visit, however if the engineer investigating finds access to your property is required, you will be contacted to agree a time when the engineer can attend. If this happens we recommend contacting us immediately to book the engineer appointment.
I'm not sure why previous agents were not able to identify the issue, but I am delighted they are able to respond so quickly. I will keep you updated.
Best regards.
Skynet_TX
Message 4 of 5
Hi @Ryan321,
Does the LED on the router remain solid white all of the time when you are having these issues ?
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
