Line activation
Redonak
Message 23 of 23
My line activation was yesterday but I waited until today and yet the router is still flashing a blinking amber colour and there is still no connection. Can anyone help me with this? Thank you.
22 REPLIES 22
Message 1 of 23
Hi Redonak
I'm so glad to hear this 🙂
Thank you for letting us know.
Message 2 of 23
Hi Debbie, the engineer just came to fix it and it is all up and running now. Thank you so much for your team’s quick response. Greatly appreciated! ☺️👍
Message 3 of 23
Hi Redonak
Just sent it now 🙂
Message 4 of 23
It is enabled now, thank you.
Message 5 of 23
Hi Redonak
Thank you. I wont be long, I just need to get your Private Messages enabled so I can send the message.
Message 6 of 23
Thank you so much, will wait for your message then.
Message 7 of 23
Hi Redonak
No problem. I'm just sending you a Private Message to confirm some details so we can arrange this visit.
Message 8 of 23
I think it is much better for me to arrange an engineer visit please.
Message 9 of 23
Hi Redonak
Ok, the 2 options we have are to send another router for testing to rule out any equipment faults or arrange an Openreach engineer visit.
How would you like to proceed?
Message 10 of 23
  • I’m afraid no, I’m quite new to this flat so I don’t know anyone who I can borrow a phone to. Is there any other option to check it?
Message 11 of 23
Would it be possible to borrow a phone for testing purposes so we can check to see if you have a crossed line please?
Message 12 of 23
I did found out about that link and I did exactly what was in there yesterday. But it is still not working unfortunately, still the same.
Message 13 of 23
Yes I have also done the factory reset, I hold it in for 30 seconds. I have also tried to turn off the router for full 30 minutes after that. The main socket has a test socket yes. I initially didn’t use the filter because the phone and broadband is already separate. But I found out that it was not working so I removed the socket cover and directly plug it in the socket with the filter on.
Message 14 of 23
Sorry for the delay. Can I just confirm, that's also after factory resetting the router? Does the main socket have a test socket?
Your guide to main phone sockets
Message 15 of 23
I have also tried to plug and unplug it from the main open reach socket but it is still the same.
Redonak
Message 16 of 23
I have tried doing both of it but it is still showing a flashing amber light. Still the same, no internet connection when I tried to connect my devices.
Message 17 of 23
I have already added the telephone number on my profile. I’m not sure about that, but I have connected it to a Openreach socket.
Message 18 of 23
Thank you. I've run a test on the line now which is clear and the connection stats also look ok. Could you try factory resetting the router and then re-setting it up again please. If it still won't connect following this then can you also try powering down the router for a full 30 minutes.
Message 19 of 23
I don’t have a physical landline phone set here but I have received an email with the Talk talk phone number. I have added it to my profile.
Message 20 of 23
Are you able to log into your My Account as the telephone number will show in there? Is this a Future Fibre (FTTP) connection or FTTC?
