Urgent Help for Significantly Reduced Speeds!
Scorpio71181
Message 13 of 13
I have had the Fibre 65 Package since last year now and it had all run smooth from after the stabilisation period but now, for the last three days, the connection has being reduced from an average of 40 - 60 mbps to 1 - 3 mpbs (download). I have tried solutions on the service centre which none have worked and I cannot get through to customer service.  I have tried factory resetting the router and have only connected up to one device and this has still not worked what can I do to get this sorted?
.docx file included with Speed Test Screenshot.
Thanks,
Tracy A.
12 REPLIES 12
Message 1 of 13
Hi Scorpio71181
Openreach have now closed this fault.
Please can you retest and let us know how the connection/speed compares?
Message 2 of 13
Hi Scorpio71181
No problem. I will check on this again later this afternoon.
Message 3 of 13
Ok thanks for telling me!
Message 4 of 13
Hi Scorpio71181
The fault appears to have been assigned to a line engineer this morning so we should hopefully receive further updates later today.
Message 5 of 13
Hi Scorpio71181
No problem. I will check on this fault again tomorrow for any additional updates from Openreach.
Message 6 of 13
Ok, thanks for your help!
Message 7 of 13
Hi Scorpio71181
Thanks for confirming this.
I have passed this fault straight over to Openreach to be investigated by a line engineer and we should receive further updates within the next 48-72hrs.
Message 8 of 13
Hi Debbie, Thanks for your reply, the router is not connected to the test socket but I have tried this multiple times like the service center suggested
Message 9 of 13
Hi Scorpio71181
I've completed a line test which has detected a potential fault.
Is the router currently connected at the test socket?
Message 10 of 13
OK, the support team will check as soon as they can when they are back online tomorrow.
Message 11 of 13
we have suffered mild weather but not severe and our other TalkTalk services work without a problem!
Message 12 of 13
Have you suffered any severe weather in your area recently? Is the phone service working OK with no noise on the line? Subject to that this has been flagged to the support team for you and they will respond as soon as they can.
