Eero 6 WAN IP address Error
hampshirehog2
Message 2 of 2
What is NOT told is that eero can only be accessed from a mobile phone and there are no plans to introduce a Windows or IOS interface.
1 REPLY 1
Gondola
Message 1 of 2
It is made perfectly clear that the control of the eero6 and eero network is via the eero app on a compatible mobile phone running iOS or Android.
Do you have a problem with setting up the eero app or eero network?
The eero Support Hub is your go-to resource for information, guides and Community support
Select here:
eero Support Hub
eero 6 and eero Pro 6 Help
eero - Setting up your eero
 eero app
 Using eero advanced features
 Managing eero profiles and devices
