Poor upload speed
maggotbraine69
Message 8 of 8
Hi, posting here as a last resort to see if anyone has any suggestions before I try switching to another provider!
Since having full fibre installed my upload speeds have dropped from typically at least 10Mbps to 0.2-1Mbps. I've spoken to support and tried resetting the router, using wired and wireless connections on multiple devices, and nothings helping. I thought I might try updating the routers firmware but I can't figure out how to do that. Any suggestions greatly appreciated!
7 REPLIES 7
Message 1 of 8
Hi again,
Thanks for trying this.
  • Name
  • Telephone number/account number
  • Alternative contact number
Message 2 of 8
Thanks for the suggestion. I've just run a few speed tests connected directly to the ONT and I'm getting identical Ping and Download speeds (19ms and 68-70Mbps) as when connected to the router, while the upload speed is varying between 2 and 4 Mbps, whereas when connected to the router I was getting speeds below 2 Mbps.
Message 3 of 8
Thanks for confirming. What speeds do you see if you remove the router and run a wired speed test directly at the ONT please?
Message 4 of 8
Thanks yeah I should have mentioned I'm using the Talktalk wifi hub 2 I  think its called? Model FAST 5464.
JacekJ
Message 5 of 8
If you're using eero6 router then software version check and update can be done using the eero app. Go to settings (bottom right corner) -> software version. In here you will see the current software version and you should have the ability to download and apply updates. Current eero6 software version seems to be v7.1.0-3704
But I doubt that updating firmware will help with your upload speeds. Esp. if you experience low speeds on cable...
Message 6 of 8
Hi Debbie thanks for the reply, yes I did try this, unfortunately didnt fix it.
Message 7 of 8
Have you tried powering down the router and ONT for a full 30 minutes? (not a quick reboot)
