Home Phone
Grandstream permanently engaged
Gleha
Message 19 of 19
Made one phone call out this morning and since then cannot call out as always get engaged tone.
Have tried switching off eero and grandstream 3 times.
Have reset grandstream to no avail.
Have tried to call in on my mobile and get a horrible echoing noise.
this is a similar situation to what happened a few weeks ago when Talk Talk had a technical problem and we were without a home phone for 4 days.
Anyone else having problems
18 REPLIES 18
Message 1 of 19
Just to add to this, an incident has been raised and is under investigation.
We’re aware that some customers on our Full Fibre service are intermittently unable to make a call. Some customers are getting an engaged tone when a call should be connected.
We would like to apologise for any inconvenience caused during this time. Our engineers are investigating this problem as a priority.
Message 2 of 19
Hi Gleha,
How has it been since your last post?
Message 3 of 19
Yesterday afternoon I had to reset the Grandstream at 4 pm because again I was getting the engaged tone when ringing out.
It has happened again just now and I have had to reset the Grandstream.
Obviously this is not very good as I am unaware until I try to ring out that my phone is not working.
I am a carer for my 97 year old mother and she has an alarm that connects to this phone, if it is down and she has a fall I will not get the alarm.
There must be a more serious fault on the line because this has happened 3 days running.
Please can you report it to your technical people
Message 4 of 19
Ok I understand. Please let us know how you get on.
Message 5 of 19
I have just checked and have the latest version of Chrome.
Re-logged in, still have same problem
Re-logged into Edge and Chat available!
It's a real puzzle
This is taking a lot of time so I'm going to leave it for now.
I will try again in a week's time and get back to you.
thanks for your help
Message 6 of 19
Hi Gleha,
Thanks for trying this. Do you have the latest version of chrome? It's strange how it works with Edge but not with Chrome.
Message 7 of 19
Just tried clearing all history, data and cleared cache for all time.
Relogged in - no difference
Message 8 of 19
Hi again,
Thanks for confirming. Have you tried clearing the cache in your Chrome browser?
Message 9 of 19
Took me a bit of time to sort out because I generally only use  one browser.
I realised I have Microsoft Edge on my laptop and used that and I can access chat through that.
I don't really want to go that route because I don't want to use Microsoft Edge on a regular basis.
Plus, next time I have to contact you re fault (which I hope will not be often) I 'm not sure I'll remember that I have to use Edge.
If it can be resolved to use through Chrome it would be appreciated.
Message 10 of 19
Morning Gleha,
Ok thank you. Would it be possible to try a different browser just to see if this works please?
Message 11 of 19
Hi Michelle,
I use the same browser as I always have which is google chrome on a samsung tablet and a HP laptop using Windows.
I have tried both devices and have same message on both.  My account seems to think I am in the middle of a chat conversation, I recognise the message from being in a conversation previously and having 2 tabs open and having to switch to previous page.  This is not the case now as I have not started or been able to start a conversation.
thanks
Message 12 of 19
Hi Gleha,
Sorry for the delay. I've been testing this myself and I also got the error message in My Account, however a few of my colleague also tested and it works fine for them. Can I just confirm, have you tested a few different browsers to see if this works? What device are you using please?
Message 13 of 19
A blank box appears with instructions to go back to previous page or log in.
I am logged in and have not started a conversation .
Last time I used the chat box was when we had previous phone issue couple of months ago
Message 14 of 19
Thanks for confirming this. What happens when you click on the chat button in My Account, do you see a specific error message?
Message 15 of 19
That works but how do i get to that if not through my account
Message 16 of 19
Hi again,
Thanks for confirming and I'm glad to hear that this is now working. In regards to the chat button in My Account, does the below Live Chat button work ok for you?
How to contact TalkTalk Broadband - TalkTalk Help & Support
Message 17 of 19
I had tried that but have redone it and seems to have worked. Thank you.
For some reason when I log onto my account the chat button won't work to report a fault.
Since having the eero and grandstream, I have never been able to check my line or internet as it says my package is not supported and to speak to a member of the team, but have no access to chat now.
That leaves the community as my only means of contacting Talk Talk.
someone else on the forum had the same problem regarding the chat button not working, is there a solution
Message 18 of 19
Hi Gleha,
I'm really sorry to hear this. Can I just confirm if the you reset the DVA following the below please?
RESETTING YOUR DIGITAL VOICE ADAPTER
If your Digital Voice adapter or router has stopped working, we may ask you to reset it to check everything's working as intended. To do this:
  1. Insert a pin or straightened paper clip into the hole labelled “Reset” on your Digital Voice adapter.
  2. Slightly push and hold it in for up to 20 seconds; or until all the lights, apart from the power light, switch off. Once this happens release the reset button.
Factory reset of the device will take a full 15 minutes and you need to wait until the allotted time has passed for the full factory reset to be completed. After 15 minutes, check your Digital Voice adapter device and try to re-test to check if the issue resolved.
