Home Phone
thinking about switching to fibre had some questions
zoa189
Message 10 of 10
my main question was if i switch tofibre without a landline would i still be able to make phone calls via fibre with the same telephone number
9 REPLIES 9
Message 1 of 10
Message 2 of 10
thanks chris this was helpful😀
Message 3 of 10
It depends on the network provider, if it's Openreach it should be available but if it's City Fibre then it probably won't be yet
Message 4 of 10
is talktalk tv available / compatable with the data only packages? and if yes how do i add it?
Message 5 of 10
It would say full fibre with VoIP but it may not be available if the only option showing is data only
Message 6 of 10
which packages would supply voip
Message 7 of 10
Sorry, no, if it's data only this means no VoIP
Message 8 of 10
i was thinking of switching to fullfibre150 dataonly and adding talktalk tv does this come with the voip option?
Chris-TalkTalk
Message 9 of 10
Hi zoa189,
Do you mean switch to full fibre (FTTP)?
You may have the option of Full Fibre with VoIP, keeping your existing number.
