Regular Contributor
Nectar account
When going into my nectar account I cannot get past the first page, everything freezes, so unable to use my points, can anyone advise?
Topics: 30
Kudos: 620
Solutions: 213
Re: Nectar account
Hi theresa,
Is the part of the site you are trying to access a secure page by any chance? You may need to amend your MTU setting on the modem. What type of modem are you using?
Cheers
Em x
Regular Contributor
Re: Nectar account
I am using a smartex 882
Regular Contributor
Re: Nectar account
My MTU is at 1432, I am now going on hol so will have to check when I get back for any more information, many thanks
Regular Contributor
Re: Nectar account
Back from my hols and the situation has not improved, posted this again today under my account, sorry if I should not have done this so have deleted.
Topics: 30
Kudos: 620
Solutions: 213
Re: Nectar account
Hi Theresa,
If that is the only site you are having difficulties with its unlikely to be anything to do with your broadband connection itself. What operating software are you using?
Cheers
Em x
Regular Contributor
Re: Nectar account
Hi, I am using Windows XP and yes it is the only site I am having problems with.
Regular Contributor
Re: Nectar account
you could try changing your MTU to 1400.
Regular Contributor
Re: Nectar account
or even 1431.
Regular Contributor
Re: Nectar account
OK will do, thankyou for the help given, I think this forum is great reading and I have learnt a lot from it.
Regular Contributor
Re: Nectar account
let me know if that helps, do you know how to change your MTU?
Regular Contributor
Re: Nectar account
Yes, I have changed it and tried both numbers but has not made any difference.
Regular Contributor
Re: Nectar account
Have tried once more on 1431 and IT WORKING, great, I can now spend some points, thanks once again for all your time
Regular Contributor
Re: Nectar account
Thats great! :-)
