Occasional Contributor
Talktalk Router not working
I recently received a router from TalkTalk, at first it would switch on fine and I could connect to set it up, but now when I plug it I only get 2 lights, Power & Internet, both of which are red, no Wifi network shows up for me to connect to, and it also doesn't work with an ethernet cable. Everything is plugged in the same and the cables work with an older router. The Talktalk router will also sometimes look like it is resetting itself by the lights changing for a few seconds. When switching it on the ADSL light flicks on for a second then dissappears.
It is a huawei hg533.
I have tried the reset button and the Wlan button but it is still the same.
This is what the router looks like:
Trusted Contributor
Re: Talktalk Router not working
hi it looks like the router has bricked somehow
during a software update
your best bet is to get an OCE to request a replacement router for you
as there is no way around this as talktalk dont supply the Firmware to recover the router
Hi, thanks for your reply. May I ask what an OCE is?
Trusted Contributor
Sure an OCE is the ones who we contact on here for help they are quicker than ringing talktalk themselves and speak proper english
Ohh I see, how would i arrange a replacement with those? Appreciate the help!
Trusted Contributor
your most welcome with the help
an OCE will see this and be able to assist then just make sure your profile contains your landline number
so they can assist much quicker
so bare with them and they will get to you shortly
Thanks!
Topics: 46
Kudos: 1,707
Solutions: 795
Hi luke_hobster
Thanks for your post,  Welcome to the community.
It does seem that the new router has died on you,  I will request a replacement and a returns bag for the faulty one.
Allow 3-5 days for delivery.
Thank you!
Topics: 16
Kudos: 2,455
Solutions: 153
Hi luke_hobster,
Let us know how you get on Smile
Re: Talktalk Router not working [SOLVED]
New router received today, all set up and working! Thanks
Trusted Contributor
glad its all sorted for you Smile
Topics: 16
Kudos: 2,455
Solutions: 153
Hi luke_hobster,
Thanks for keeping us updated Smile
Using it for the past couple of hours has been painfully slow, I have had to put the old router back in (old router works so definitely no ISP problem). Any ideas of why it could be going so slow?
There are multiple devices connected to it at the same time around the house - laptop, 2 phones, 2 ipads, sometimes another 2 laptops...
Topics: 23
Kudos: 1,731
Solutions: 588
Hi Luke,
Can you run a check on the Service Centre with the new router in place and follow the report and repair steps.
Cheers
Smile
