Online security
Get answers and information about our security products.
Unable to edit the kid safe setting on my home Wi-Fi
KGeeO
Message 10 of 10
I am unable to edit the kid safe setting on my home Wi-Fi, when I make a change, and try to save my changes, I get the following message below:  "There was a technical error
We’re sorry and working hard to resolve this. Please try again later."
KGee
9 REPLIES 9
Message 1 of 10
You're welcome.
Ady
Message 2 of 10
That's fine. Thanks Ady, much appreciated.
BigCat
Message 3 of 10
Hi BC, I've turned on the settings you requested. I've not changed the File Sharing, games and file sharing. If you need those blocking too just shout.
Ady
Message 4 of 10
Hi Ady,
I have a similar problem in that I cannot update the Kid Safe settings.
In my case if you could remotely update so that all the "Unsuitable for under 18s" website categories are ticked i.e. no access, that would be great.
BC
BigCat
Ady-TalkTalk
Message 5 of 10
Hi Dbb1982, you would need to call customer services if you want to speak with someone on the phone. We only offer support via the community here on the community.
It's very odd that it should work for me and not you as we're accessing the tool in the same way using the same portal. Do you use a VPN?
Ady
Ady-TalkTalk
Message 6 of 10
When I turn your homesafe on or off I do it via your MyAccount the same as you do. Have you tried another browser too?
Ady
Message 7 of 10
Dbb1982, I've done the same for you checking your account and again it worked perfectly. Have you tried clearing the cache of your browser?
Ady
Ady-TalkTalk
Message 8 of 10
Hi KGee, I've just made 2 changes in your kidsafe. I blocked gambling then allowed it and both changes showed as successful with no errors. Could you try again and let me know if you're still having problems.
Ady
Dbb1982
Message 9 of 10
