Set top box for TV
Ajayg
Message 2 of 2
Almost every month I need to reset my set top box & yesterday I lost connection even after reset.
So I do not have any TV
1 REPLY 1
Message 1 of 2
Which box do you have do we can offer advice?
If you have a TV with a Freeview tuner, plug the aerial directly into the TV so you can watch.
