TV Box 4K
Granbelle
Message 2 of 2
Just received the TV Box 4k a couple of days ago and have been learning how to use it.    Lots of trial and error but getting there.  I have set up a number of recordings.  When I press Home/Recordings I can see the most recent recordings as well as the scheduled programmes still to be recorded.  So far so good.  However I noticed a couple of programmes that were not showing as having been recorded.  I wondered whether perhaps I ran out of space?  Checked Settings/Storage and lots of space available.  It showed 12 recordings.  So I go back to the Recordings screen and I count the number of recordings.  There are only 10. So where are the other 2?  How do I access them?  Can anybody throw any light on this query?  Also, It would be really useful to find a User Guide/Manual that I can download, if anybody can point me in the right direction.
1 REPLY 1
Message 1 of 2
For a guide, search Netgem 4k box. You will find a generic manual for the retail box, which has the same functionality as the TalkTalk one.
As for your missing 2 recordings, are they part of a series record? If so they may be hidden behind one you can see. I haven't got mine up to check but hopefully the manual will help.
