on 15-03-2024 04:30 PM
Setting up is ask for Google account do I need this. Should I set up from my phone or manually
on 15-03-2024 04:36 PM
You will need a Google account yo be able to install apps on the box
If you have an android smart phone, chances are you already have an account. You can use the same details on the Hub box.
If you don't have an account it's probably easier to do on your phone and then once set up install the app and link the accounts.
