Draytek 2820n fibre compatible ?
3 REPLIES 3
typoid
Can anyone help?
I was given by TalkTalk the Huawei HG633 for standard broadband some years ago. It proved to be of little use; slow. You can spend days on tech support and I couldn’t face that so my son gave me a Draytek 2820n. It was great.
I have just started a contract on fibre.
Is the Draytek 2820n fibre compatible ?
Any help appreciated
martswain
Any search engine is your friend !
Looks like it is not VDSL compatible.
Martin
typoid
Ta for response
I spent last night and this morning searching but got confusing info.
Was hoping a poster here may have already had experience with this modem.
It does seem its not possible but others have used some kind of hub.
Gondola
Hi @typoid
Martin is spot-on.
The HG633 is fibre to the cabinet compatible and has had a great software update to v2.0t  but you may wish to consider the Wi-Fi Hub if that hasn't already been provided to you.
 Gondola - Community contributor
