Problems with wifi not connecting
5 REPLIES 5
dungbat
 DSL-3780 router wifi is on. All 3 of the kids cannot now connect their xboxes. Hudl tablet when trying to connect displays `Obtaining IP address > Saved > Obtaining IP address > Obtaining IP address > Saved > Obtaining IP address etc etc.
Have swapped router, same model, still getting nowhere.
Main wired pc is working perfectly.
It sounds like you are having an issue with the DHCP allocation of IP addresses, but it may be something more basic. Have a look at my attached guide.
dungbat
***** SOLVED changed some settings in router *****
dungbat
Hi, some advice from a earlier query on the forums was to change to `Always On` in the `Internet Setup` settings. Seems to have done the trick. But thanks anyway.
Peter1948
My router is C2AAF8, when I try to connect remotely with my laptop it will not pick up the talktalk network but does recognise and displays my next door neighbours Router which is a BT Hub???? Any suggestions?
Peter1948
Sorted thank you, Didn't even know what a WLAN button was, I do now.
Pete
