Sagemcom Fast 5364 - bridge mode
23 REPLIES 23
Whizz Kid
I've just received my replacement modem and I cannot see any place where I can put it into Bridge mode as I was able to with the Huwei router I'm currently using.  Is there any way to do this or is this modem of no use to me as I need to use it as a modem only.
No. Why order a top-class router and not use it?
Whizz Kid
I didn't order it.  I just updated package and it comes with it.  I asked if it was going to be sent and was told that it comes automatically.  I would prefer a modem only but, as with most ISP's, TalkTalk assume that because they have a good router everybody would want it.  I have my own reasons for wanting a modem only.
Hi.
Did you find a solution to this?  I have the same problem... Using whole home Wi-fi (Netgear Orbi) but TT router interfering.
cheers, John
It doesn't support it
https://community.talktalk.co.uk/t5/Your-Ideas/Supply-modem-only-Bridge-mode-on-wifi-hub/idi-p/22242...
HG635 is the next best option from TT, or else a third party model.
its support just we need enable it
{name:"user.mysagemcombox.bridgemode",state:{url:"/bridgemode",templateUrl:"views/mysagemcombox.bridge-mode.html",controller:"BridgeModeController",data:{module:"bridgemode"}}}
Whizz Kid
The previous post states quite clearly that this router does not support bridge mode.   Why do you think it does and do you have some idea how to enable it?
😉  it exist abut need to be anabled in firmware , or maybe loged as poweruser will allow change 🙂 bridge.png
So could you kindly explain to everyone here precisely how log in as a power user and  to achieve this. Please.
@apols How do you enable it in the firmware?
Forma
Whizz Kid
I've only just got around to looking at my router again and I can't find a way of getting the bridge mode screen up.  There has been mention of a power user, does anybody know how to use that?
can't be enabled until talktalk not allow this in firmware 😞 but option exist .
 apols First Timer
You appear to have shown a screen shot informing the community that the Sagemcom Fast 5364 can be switched to bridge mode.
So could you kindly explain how one can acheive this, please.
Showing that is can be done but not explaining how to achieve this does not really help anyone trying to the this router.
Thank you
@donnieyengta  read again , i just show that the option exist but is greyed out , so the development team can make it active - but for some reason they don't wona make this 🙂
Whizz Kid
I don't have a page with Bridge Mode on it at all.
no one see it , is hidden same as TR69 , /mybox/maintenance/tr69
Sorry I am very new here and I just wonder if anyone has got the solution for the bridge mode? In fact I just installed TT today and just ordered my Orbit mesh system. Then I saw this comment. It’s a big shock and please tell me there is a way to enable the bridge mode.
Otherwise, can we at least change another hub? All I need is a modem.
thanks,
Shaun
Has anyone found a solution to this yet?
i use openreach as modem 🙂without problem
Whizz Kid
I think you missed the point.  I know that I can use a different router in bridge mode or a modem only, the point I was trying to make was that it isn't much use sending out a router which doesn't have the ability to use bridge mode.  It just becomes a piece of junk and therefore wastes money.
