For any questions about your TalkTalk mobile service.
on 05-06-2022 02:41 PM
Hi, I'm spending the summer in Europe and have just learnt that I can't increase my meagre 500mb mobile data with TalkTalk. (Hoping for around 5Gb). I'll need to transfer to another provider. I want to travel soon with minimum mobile transfer fuss. Can anyone suggest such a provider that includes EU data roaming at UK rate of about 5GB? Thanks.
on 05-06-2022 02:54 PM
P.S. You might find this helpful from MSE:
https://www.moneysavingexpert.com/mobiles/cheap-roaming-calls/#europe
on 05-06-2022 02:48 PM
There are plenty of comparison sites out there. A whole host of providers can provide the allowance you require cheaply, but since Britain left the EU you need to be careful that whichever you choose has roaming included. Bear in mind that you will need to get a PAC from TalkTalk and transfer that across if you want to keep your existing number, I would allow a minimum of 3 days for that.
