Internet drops every day
Tomwebb64
Message 13 of 13
I recently joined talktalk (line activation was almost 3 weeks ago) and over the last 2 weeks my Internet has been disconnecting at random times, usually multiple times a day. I had an engineer come round the same day as the line activation and he fixed my master socket as there was a damp issue, for the first week the Internet was fast and had 0 drops. With around 3 days to go until the end of the 2 week stabilisation period, the Internet began to disconnect from the Internet (the router light would go from white to flashing Amber), and this persisted intermitently for a few hours. Then each day since then there have been atleast a few (sometimes a lot of) disconnections per day. They only last about a minute each but can really get in the way of my work. I have contacted  customer services twice, the first time was before the stabilisation period had finished so they told me to contact them again if it was still happening afterwards. So I did, and was told that some changes were made and that the problem was fixed. Although it did reduce the amount of cutouts, I still get a few, usually late at night. The last cutout was at 4:12 am, and was wondering if anyone else could help with the issue.
I've had a line test run 4-5 times and each time was told that everything was fine.(although as the cutouts happen so quickly, I have not been able to test during one)
I have the sagecom fast 5364 router.
I do not have a land-line so cannot check for sound on the line and the dropouts can't be caused by phone calls.
Thank you in advanced.
12 REPLIES 12
Message 1 of 13
Glad to hear the connection has been more stable.
Message 2 of 13
Hi sorry for the late reply, I've been away and forgot to check when I got back, the issue seems to have subsided and I have not had any dropouts since returning. Thank you for your help.
Message 3 of 13
Hi Tomwebb64,
If you remove the faceplate of the master socket that your router is currently connected to, does this disconnect the other master socket?
Message 4 of 13
Have been doing some searching around, I have 2 master sockets next to each other, could this be the underlying cause, or is this perfectly fine? They are both mastersocket 5C's although one is connected to the other which is wired to the incoming cable. My router is connected to the one with the direct connection.
Message 5 of 13
Hi, I do not have a spare router, however I can test out the test socket, how long should I leave the broadband connected to the test socket?
Message 6 of 13
Hi Tomwebb64,
Thanks for trying this, we can now focus on the intermittent connection. The line test is detecting a fault close to the property. Just to confirm, do you have an alternative router that you can test with to rule this out?
Does the master socket also have a test socket?
Message 7 of 13
Have now recieved my landline and have plugged it in and there is a faint hiss but no intermittent noise.
Message 8 of 13
Hi, still waiting on my landline.
Today I have been having issues with both dropping connection and slow speed.
My speed is currently 6 mbps, well below my guaranteed minimum of 49mbps.
Message 9 of 13
Hi Tomwebb64
Thank you, please let us know how you get on.
Message 10 of 13
Hi Debbie, I don't know anyone who can lend me a land-line but I have just ordered one to test the line. It will arrive on Wednesday, I will get back to you on whether there is noise on the line.
Message 11 of 13
Hi Tomwebb64
I've completed a line test which has detected a possible fault.
It would be worth ruling out any issues with your landline service as this can affect the broadband connection, even if the phone is not in use.
Would it be possible to borrow a phone just for testing purposes?
Message 12 of 13
That does sound like the hub is losing connection with the exchange or fibre cabinet. I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
