Box failed to record
Debbow
Message 8 of 8
Having trouble with the you view box, not been able to record for a few days now, tried the reset a few times, but still no joy, any advice would be grateful, thanks
7 REPLIES 7
Message 1 of 8
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
andyaroberts
Message 2 of 8
I'm having real problems with my set top box - unable to record anything or playback and pre-recorded programmes. Just recently i've been receiving the message 'failed to record'!
I have reset the box but had no joy.
Do I need a new box? How do I proceed?
This has been an issue for several weeks now - very frustrating!!!
Message 3 of 8
You're Welcome.
Message 4 of 8
Thankyou Karl, much appreciated.
Message 5 of 8
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 6 of 8
Tried all the different reset procedures, read up on here first to find out what others had done, seems its quite a common problem.
Message 7 of 8
What reset have you tried?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
