Box not working properly at all.
Nairnite
Message 3 of 3
Talk talk YouView box is doing all manner of strange things. The pause does nothing. It just keeps playing and if you try to fast forward it takes at least a minute to comply but that is just if it actually does it all. The picture freezes but the sound carries on. It is a 50/50 chance that the recordings will actually record or not. Sometimes the recordings will not stop. They just carry on for hours. We have to reboot the box at least ten times a day. The box often turns itself off  or the screen just goes black. If you are watching a recording it just keeps playing even if you are trying to stop it. No button on the remote control will work. Again the system has to be turned off . It only works for a certain amount of time then we have to go through the same procedure again.
Nairnite
Message 1 of 3
Try the reset advice and let me know if this helps.
Message 2 of 3
First, have you changed the batteries in the remote to see if the box responds better?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Also, as TalkTalk no longer provide recordable boxes, if recording is important to you, then the above is your only option to getting the box to work, if it can be reset satisfactorily
Hope it works but if not then you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
