Error code IPC6023
sammyhaine
Message 67 of 67
I have had this error code now since middle of January, tried talking to talktalk customer services who said it was my internet, well if that is the case why can I use my bbcIplayer and Netflix via my tv box but not view normal channels if its my internet?  Also can not log in to my router to change any settings on it at all not by using admin admin or admin with its unique password, even factory reset all equipment and the problem still occurs every time!  Can someone please help as I am getting rather fed up paying for a service that I clearly aint getting the use of.
66 REPLIES 66
Message 61 of 67
I don't have a phone to plug in to check, however I only moved to this property on 09/02/2018 and had the same issue at my previous address in burnley.
Message 62 of 67
Multicast settings look ok, but I am picking up an increase in errored seconds on your line.
Also, I'm detecting a bettery fault on the copper line side.
Can you check your home phone and tell me if there is a clear dial tone on the line.
Message 63 of 67
I have updated my profile now thank you
Message 64 of 67
Hi sammyhaine
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
fre55die
Message 65 of 67
Hi @sammyhaine
I've escalated this for you.
Could you please ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information, Settings, Personal information, then scroll to the bottom of page and click save)
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
sammyhaine
Message 66 of 67
is anyone able to help i have done the reset router, reset tv box, everything and still no channels yet can sit and watch my netflix so clearly there is net going to my box
