on 14-06-2021 11:43 AM
My HD channels (101-105) are showing a black screen, although the guide is showing programme info. SD channels work fine and I can stream through iPlayer or Netflix etc.
I have tried a factory reset, soft reset, removed all cables and replaced cables.
on 14-06-2021 12:16 PM
Can you connect the aerial direct to your TV and see if the HD channels are showing correctly on the TV.
on 14-06-2021 12:02 PM
It could just be the weather I'm afraid:
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
