How do I search for a film please?
Angela Wall
Message 2 of 2
Please can someone tell me how to search for a specific film?
1 REPLY 1
Message 1 of 2
In which application?
Most can be found using the search search function by pressing the search button on your remote.
Some apps are not integrated so you may have to search within Netflix or Prime individually.
