Huawei box not responding to handset
Witchkoko
Message 5 of 5
Box not responding to the handset except the on /off button. Only way to get it working is to restart box every time. This is happening every couple of days and happens at the most inconvenient times.
I have tried all the resets including a full factory reset loosing all my recordings.
4 REPLIES 4
Message 1 of 5
OK, it may be the box itself. I can swap this out but this will be for the non recordable model, would you like me to send this ?
Witchkoko
Message 2 of 5
after the reset everything works fine until the next time
Message 3 of 5
After the reset, did all functions of the remote work as normal ?
Message 4 of 5
Hi @Witchkoko
I've just seen your post has not been auto escalated into the support staff's queue.
I have manually done this now, so you should hear soon.
