Losing Sound and picture pixelates while watching BT & Sky Sports
Chunkyis
Message 15 of 15
While watching BY or Sky Sports through my talktalk box, the sound drops and picture pixelates momentarily every few minutes.
14 REPLIES 14
Message 1 of 15
I've asked my network colleagues to have a look at my findings and the Openreach report and give me a second opinion.
Message 2 of 15
Hi Karl  I'm starting to pull my hair out now and I'm sure you're about to do the same but please stick with me. BT/OpenReach Engineer attended this morning,  did all the tests which all came back OK apart from some very minor errors which be said were more than acceptable.  He said he thought it was a Bandwidth problem and that reducing the number of connected devices should solve any further problems.  The same thing started happening during Arsenal's game with Liverpool tonight so I disconnected/turned off every wired and wireless device connected to the broadband apart from the talktalk TV box which is hard wired to the router with a new lead.   Even with no other devices running,  the sound continued to drop out and picture pixelate and freeze.  I'll keep the recording again should yet another engineer be required.  Any further thoughts my friend ???
Message 3 of 15
Brilliant - Thanks again Karl !
Message 4 of 15
Engineer Booked for Wed 15th (tomorrow) AM (8-1).
Message 5 of 15
Hi Karl,  Tuesdays, Wednesdays or Fridays are best for me but after 2pm on Mondays and Thursdays are also good.
Many thanks
Paul
Message 6 of 15
All my usual line tests are passing here, but i've pulled the DLM logs from the BT system for the past 72hrs and there are some errored seconds showing throughout the day.  Not high errors, only in single figures but these are consistent at all times every day so an engineer will be required.
what days are best for an engineer visit.
Message 7 of 15
Hi Karl,  I've installed the replacement talktalk tv box with the new leads enclosed but I'm afraid the problem is still the same.  I have noticed that it seems to do it more regularly during evening football games when I would imagine there is peak Internet use.  I watched a lunch time kick off and it only did it three or four times during the entire game, were as at other times, it's cutting out every minute or so, which is very annoying.  I've saved recordings for any future engineer visit should you deem that to be the next course of action.
Many thanks
Paul.
Message 8 of 15
I'll swap out the TV Box and see if that is at fault.  Replacement is on the way.
Message 9 of 15
Hi Karl, Set the replacement Super Router up today using the enclosed new leads but I'm afraid it's continuing to do it.
Paul
Message 10 of 15
No Problem 🙂
Message 11 of 15
Many thanks Karl
Message 12 of 15
I'm going to swap out the router first, to make sure there are no issues with this dropping the igmp data for the IPTV signal.
Message 13 of 15
Hi Debbie,
Yes it's wired direct to the router and I've checked the connections are secure.  I've also ruled out a lead fault by trying different leads.
This is a long standing problem which has come to the fore again now that I've been able to resume watching football.  I recently upgraded to Superfast broadband and have had a new super router and had a BT Engineer out who checked and re-wired my home to get my broadband upto speed.
I can only think it's either a fault on the talktalk tv box which works fine on non subscription channels but keeps cutting out intermittently on BT & Sky Sports, or the broadband connection keeps cutting out for a split second every few minutes.
Message 14 of 15
Hi Chunkyis
Is your TV box connected wired to the router or are you using power line adapters?
Are the cables all connected securely at the back of the TV box?
