Missing remote
flowdy
Message 2 of 2
Hi, I received my talktalk tv box but there's no remote, just the box itself and all the cables. Is the normal? Could you send out a remote for me please?
Rflowdy
1 REPLY 1
Message 1 of 2
Is this your first box, or a replacement? If the latter then your existing remote will work with it.
