Network Connectors
Kazzy-
Message 6 of 6
One of my network connectors isn't working so that means I cannot use the apps etc via my TV box
Kaz 🙂
5 REPLIES 5
Message 1 of 6
I'm glad to hear this and thanks for the update 🙂
Kazzy-
Message 2 of 6
Thank you thank you Karl for your swift despatch of my adapters this was so quick  ! I am now back up and able to watch all my catch-up TV i-player itvhub etc thankyou  once again,
kazzy
Kaz 🙂
Kazzy-
Message 3 of 6
Thank you Karl, much appreciated😁👍
Kaz 🙂
Message 4 of 6
Hi Kazzy-
I'll get a set of adapters out to you.
fre55die
Message 5 of 6
Hi @Kazzy-
VERY IMPORTANT FOR SUPPORT !!!!!!
Could you please ensure that your personal information is up to date in your profile INCLUDING your registered landline number
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info.
This is purely so that the OCE's can tie up your details and trace your account as this is not possible from just your screen name.
Thank you
