Picture and sound glitching, jumping, freezing constantly
Mrsjid
Message 3 of 3
For around 3 weeks now the picture and sound has constantly been breaking up, glitching and pixelating for a second or two at a time, it’s now becoming more frequent and lasting 3-5 seconds every time it does it. Trying to watch a 30 minute tv programme tonight and it must have done it more than 10 times throughout that 30 minutes. All connections checked and fine! Tried turning off and leaving it then rebooting, makes no difference! Paying for a device that is becoming unusable!
Message 1 of 3
Hi Mrsjid
Please follow the advice from fr8ys then let me know if this helps.
Message 2 of 3
have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Also if you wish to keep recording, this would be your best option as if the box is replaced, it will be a non recordable box as TalkTalk no longer provide boxes that record.
Hope it works but if not you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
