Powerline Adaptor Fault
RichardBr
Message 12 of 12
My powerline adaptor connected to my Wifi hub has stopped working. There is no power light on it and I have tried resetting it, including the factory reset option and it makes no difference. I have checked the power socket and this is working ok.
The adaptor connected to the TV box is showing both power and Ethernet connection lights ok.
11 REPLIES 11
Message 1 of 12
That's great, thanks for letting me know.
Message 2 of 12
Hi Karl,
New adaptors arrived today. Installed and all now working ok.
Message 3 of 12
No Problem 🙂
Message 4 of 12
Thanks Karl
Message 5 of 12
Hi RichardBr
A set of adapters are on the way to you.
Message 6 of 12
Hi Callie.
Could you please start your own thread for support as each problem is individual and needs investigating separately.
Message 7 of 12
Hi @RichardBr
The support staff on here only work office hours, 8-5 Mon to Fri. These are the specialist team so they will sort out your problem hopefully on Monday.
Message 8 of 12
No, I am still waiting to be contacted by support.
calliescott24
Message 9 of 12
I'm having the same problem, just the other way round, power adapter connected to tv isn't working, have unplugged, reset, bought new ethernet cables and still not working, did you find a solution? @RichardBr
Callie scott
RichardBr
Message 10 of 12
Thanks. I have checked my profile info and all up to date.
fre55die
Message 11 of 12
Hi @RichardBr
For support it is IMPORTANT to ensure that your personal information is up to date in your profile. This is purely to enable the staff to link your screen name to your account.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
