on 25-06-2020 05:47 PM
These latest issues started a few days ago with the remote control being unresponsive to the picture freezing on the screen. The main issue now is the youview box won't record any programmes & the programmes previously recorded won't play.
I've re-booted the the tv box 3 times and re-paired the Network Connector & Wi-Fi Extender boxes but the connection between them is still slow with the Powerline light being orange rather than green. Has anyone got any suggestions to solve these issues?
on 23-07-2020 07:20 AM
Sorry to hear you have lost the previous recordings.
Try some recordings going forward, and any issues, please let us know.
on 22-07-2020 04:19 PM
Hi Debbie
Sorry for the delay in getting back to you. I've installed the new connector & extender kit and there was no change. I did a factory restore & this has solved the recording issues but obviously we've lost all of the programmes we did have.
Sandrina
on 01-07-2020 06:56 AM
Hi Sandy
Thank you 🙂
The replacement adapters are on the way, please allow 24-48hrs for this to arrive.
Let us know how you get on.
on 30-06-2020 06:53 PM
Hi Debbie
I've updated My Profile as requested
on 30-06-2020 12:49 PM
Hi Sandy
Please can you add your name and TalkTalk telephone number to your Community Profile, I can then send the replacement adapters first.
on 30-06-2020 12:15 PM
Hi Michelle
Yes, please can we try another new set of adapters. If this doesn't solve the problem will we be sent a new tv box?
on 30-06-2020 12:07 PM
Hi Sandy,
Thanks for confirming. Would you like us to replace the adapters to see if this resolves this particular issue?
on 30-06-2020 10:08 AM
Have re-booted & re-paired the extender kit - no change. Have noticed this morning when the TV box is on standby all the lights on the extender box are green. As soon as the TV box is on the Powerline light is red.
on 29-06-2020 09:41 AM
Hi Sandy,
Thanks for the update. Did you try switching the adapters around? Have you also tried resetting them up again?
Fix a problem with your wireless Powerline adapters
on 26-06-2020 04:40 PM
Unfortunately the router & the tv have to be in different rooms. The Wi-fi Extender kit was showing all green lights until a few days ago. This is about the 3rd kit we've had over the 8-10 months I've had TalkTalk. Thought it might be something different as this is the 1st time we've had issues with recorded programmes. Do you think a new Extender Kit might be the solution?
on 26-06-2020 09:45 AM
Hi Sandy1968
If the lights on the adapters is orange, this indicates the communication speed between the adapters is dropping. This could affect the performance of the box.
Try swapping the adapters around, make sure the adapters are direct into wall sockets where possible.
If still remaining orange, try other wall sockets if possible to rule out any internal wiring issues etc.
on 26-06-2020 09:08 AM
Looks like a factory reset is on the cards!
on 25-06-2020 09:58 PM
