Replacement box? Where is Customer services?
Marcelo1147
Message 6 of 6
Can anyone advise how I get a replacement box? Talk Talk customer services seem non existent on here. I have had 'failed to record' one too many times. I know to fix and I am fed up with losing recordings by factory resetting. I now just want a new box. Help! Thanks.
5 REPLIES 5
Message 1 of 6
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
Message 2 of 6
Hi I have added my number. Mobile preferred. Test have already been run on the broadband. I really just want a new box sent, I don't want to spend ant more time on the phone going diagnostics. I have been through this too many times, have lost so many recordings. Now the box doesn't work at all as it won't turn to the live channel and hangs. Please can you just arrange to send a new please?
Message 3 of 6
Message 4 of 6
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if required. We will then reply via this Community.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Message 5 of 6
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
