TV+ box issues
welshie1701
Message 4 of 4
For the past month or so our TV+ box has been misbehaving. Many recordings fail, and of those that "succeed" there is usually pixelation or skipping of large parts of the show. I have tried both soft resets and a full service menu factory reset, which have not helped. TV aerial signal quality is fine, as is the internet (70+ mbps), I just believe that the TV box is on its way out! Please can you advise if it's possible to get a replacement TV box?
Yesterday it worked
Today it is not working
Windows is like that
- Famous haiku
3 REPLIES 3
Message 1 of 4
No Problem 🙂
Glad to help.
Message 2 of 4
Hi Karl,
Many thanks for dealing with this so quickly!
Seasons greetings to you 🙂
Yesterday it worked
- Famous haiku
Message 3 of 4
I can see errors with this.  A replacement is on the way.
