Tv subscription channels no longer work
barrypaley
Message 3 of 3
My tv subscription channels do not work. They were heavily pixilated for a couple of weeks but then they went. I have done all the resets except a full factory reset because I want some of my recordings. Any advice other than a full reset.
Message 1 of 3
Hi barrypaley
Are you using powerlne adapters ?
Do the channels fail with a direct connection to the router ?
Do on demand players work, such as BBC Iplayer or ITV player etc ?
Is general internet working ok ?
Message 2 of 3
A factory reset should not be needed for subscription channels.
Do you use powerlines?
Try pairing these again, and also turn off your router for a few minutes and try again.
If this does not work, you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
