Unable to view TalkTalk TV - blank screen
anthonybrighton
Message 12 of 12
I'm unable to view any talk talk tv. When selecting I just get 'TalkTalk TV' in the top left corner and a blank screen (pic attached).  I'm unable to view any of my purchased content.  It was last viewed earlier this week.  I have tried resetting the box (Humax DTR1000).
Anthony
11 REPLIES 11
Message 1 of 12
Hi Anthony,
That's great news, thanks for confirming.
Message 2 of 12
HI @Karl-TalkTalk ,
Seems to be working now, thank you for sorting.
It initially popped up with a error - TTG-203 and a retry button.  But has since been fine
Anthony
Message 3 of 12
I've raised a ticket to our platform vendor to take a look.
Message 4 of 12
Hi @Karl-TalkTalk ,
I've tried accessing a couple of times, but it is still the same.  Blank screen with 'TalkTalkTV' in the top left corner.  The 3 dots show in the centre of the screen like it is doing something, but then they freeze and nothing further.
Everything else on the box is working fine (netflix, my tv recordings etc), just not 'MoreTV'.
Anthony
Message 5 of 12
When you reset the box it will register in the system, it's not unusual to see a box registered a couple of times. I've removed all entries now so nothing is showing as registered. If you try to access More TV we can see if it registers in the system.
It's a strange issue. All settings I can see are correct, no issues with the database, your TV or account settings etc.
Same issue happened to one of our community Stars a few weeks back, all settings where ok, and a couple of days later it all worked again.
There have been no changes or updates that I'm aware of.
Message 6 of 12
Hi @Karl-TalkTalk ,
I turned the router off for 30 mins and re-tried, but it is still the same.  Your earlier message said there were 2 boxes, I only have 1 box.
Has there been a recent software update, that may have caused the issue ?
Anthony
Message 7 of 12
I can see you do not have any subscriptions but can see the purchased content in the back end system, there were 2 TV boxes registered, i've removed one of them so the first one registered at 10:15 this morning is still showing.
anthonybrighton
Message 8 of 12
Hi @Karl-TalkTalk ,
Just some further info - I do not have any subscriptions, but I do have lots of purchased content.
Anthony
Message 9 of 12
OK, last thing to try, turn router off for 30 minutes to clear the current session, then retest.
anthonybrighton
Message 10 of 12
Hi @Karl-TalkTalk ,
I've reset the box  (factory reset, keep recordings) but still no access.
Now, it flashes up with 'Finding your subscriptions' and the kicks me out back to the TV.
Anthony
Message 11 of 12
I've removed any associated devices from the system, Reset the box again and this will re-register, then try again.
