on 09-03-2020 05:31 PM
Hi there,
My Youview box has drastically slowed down in the last month or so, and yesterday it seemed to give up the ghost. When I power it on, it gets stuck on "Loading" endlessly. I've tried a different ethernet cable and port into the router, I've tried a Factory Reset on the Maintenance Menu, and I've turned it off at the wall then back on again - the solutions suggested on previous threads.
I'm not sure if there's a known fault, or if there's something you recommend I try next, but I appreciate your prompt support!
Thanks again,
Jack
on 29-05-2022 10:24 PM
Hi @gabell84
You have posted on an old post by somebody else so it is unlikely to be picked up by a member of staff promptly and I am unable to escalate it for you from here. Could you please start your own post so that a staff member can pick this up and deal with it.
VERY IMPORTANT FOR SUPPORT !!!!!!
Could you please ensure that your personal information is up to date in your profile INCLUDING your registered landline number
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info.
This is purely so that the staff can tie up your details and trace your account as this is not possible from just your screen name.
Thank you
on 29-05-2022 06:20 PM
Mine is the same, just keeps loading & I've tried everything!
on 08-09-2020 06:33 PM
I’m having the same problem I’ve tried everything could I please get a new box too thank you
on 10-03-2020 08:10 AM
No Problem 🙂
Glad to help.
on 10-03-2020 07:54 AM
Thanks so much Karl - your quick support is much appreciated. I'll let you know when it arrives!
on 10-03-2020 07:47 AM
Hi Jack
I'll get a repacement box out to you.
