replacement box freezing
redarmy
Message 15 of 15
replacement box has froze a number of times, needing a reset. (4 month old) does anyone know if BT and Plusnet youview boxes are any better.
14 REPLIES 14
Message 1 of 15
I'm waiting for an update from the TV product manager. I'm hoping he'll be able to give us a pointer as how best to proceed and get this sorted for you.
Message 2 of 15
anybody got anymore idea`s or help
Message 3 of 15
Fair enough and this is the second new box you've had?  Let me see what I can do for you.
Message 4 of 15
tried both updates. both show up running latest version
Message 5 of 15
Our system is showing it's not, if you try to run an update manually it'll tell you whether you need to do it or not. You're correct you won't lose anything.
Message 6 of 15
thanks for getting back
showing last checked 26th
component software 3.2.108
manu. software  72.44.211
platform config.  3849
isp config   2201011
looks up to date,are you saying i should update again manually. as this is normally done overnight i take it i wont lose any recordings or settings, ie. it is not a reset
cheers
Ady-TalkTalk
Message 7 of 15
They should be. Sometimes you need to run them manually. Let me know how you get on with it please.
Message 8 of 15
i thought these updates were automatic.
cheers
Message 9 of 15
Hi redarmy, the firmware on the box is in need of updating. Are you able to get that to complete?
Message 10 of 15
did the factory reset as suggested, froze again last night during a playback. remote totally unresponsive. had to reset again from back. getting a bit sick of this now. renewal is looming in a week. might as well try bt. some people reckon its a better box.
Message 11 of 15
Try performing a Youview Maintenance Reset (Option 4: Keep Recordings).
Set the box back up and see how it performs.
redarmy
Message 12 of 15
sorry forgot to say its freezing on playback
Message 13 of 15
hiya
this has happened approx. 10 times since receiving the replacement in jan. there have been no screen errors shown. we have a black screen and it reset itself back to "my tv" . most times i have had to reset from back of box.
Message 14 of 15
At what point dos the box freeze? Playback, channel changes etc.
Any on screen errors?
