Amazon Prime Constantly Buffering
Can you try a factory reset of the TV box from the settings menu then set the box back up and see if the issue still happens.
Hi Karl
Will that delete all our recordings?
John
This will reset the box and remove all recordings, but if this fails we are going to have to replace the box to rule out a hardware issue.
Hi Karl
OK. I will just check with the family tonight to make sure there is nothing they want to watch and will report back.
John
Hi Karl
I have done the factory reset and Prime Video now seems to be working.  It is not the quickest to load but I'll see how it goes.  It's gone down like a lead balloon with the rest of the family as quite a few of the Christmas recordings are lost.
Going back to post 4 is there still a fault on our line?  Bearing in mind the type of master socket we have, see picture in post 7, is there anything you would like me to do?
John
Hi John
Sorry it came to this, but glad to hear Amazon may be working correctly now.  I'm still looking at this issue for other customers.  I can't see any network issues causing this and am starting to suspect an issue with the App or how it is installed on the box.
The earth fault on your line is currently showing as clear.
Thanks Karl
No Problem 🙂
