Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Boost channels not working, black screen
leemilligan
My boost channels just show black screens. This is not the 1st time as it happened a few months ago. I have already turned off the reuter and tv box for 30 minutes, weve also pressed both front buttons to reset but its still not working. The previous time needed an engineer to the bt box a few doors away.
Please help.
Hi leemilligan
All tests are clear currently.  I'm showing that the MSAN config is correct.
I'll swap out the router first, to make sure this is not failing to process the multicast data and then we can take it from there.
Check & Report l Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars
OCE's Hours of Operation - Mon to Fri 8am to 4pm. Urgent issues outside these times, please use Live Chat
leemilligan
Thank's Karl,
Much appreciated
No Problem 🙂
Test as soon as it arrives and let me know.
leemilligan
Hi Karl,
Router arrived this morning, no change i'm afraid.
I've raised this to networks to check that multicast traffic is processing at the port.
leemilligan
Red solid light on internet light after 2 hours of being green ggrr.
Hi Lee
The fault has been passed over to our NOC teams for investigation.  I cant see any auth logs from today.
Can you try a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
leemilligan
Hi Karl,
Done that still no joy.
Does it work with the old router, or is it failing with old and new.
leemilligan
Hi Karl,
Failing with both. New one plugged back in, still red light for internet.
Regards Lee
I'll update our network teams to see whats happened.
leemilligan
No tv light on now so cant access recordings. Still no internet. Red light still on. Tried to connect by yellow cable no joy either.
Lee
Hi Lee
I'm emailing networks to chase for an update on this.
leemilligan
Hi Karl,
Red light is now off. We have internet but still no boost channels.
Regards Lee
Hi Lee
I've had confirmation from our network teams that the MSAN had switched over.  They have switched this back now and need you to retest.
Can you power off all equipment, router and TV box etc for a couple of minutes, then power on and retest.
leemilligan
Done.
Thank you so much for sorting. Smiley Face
Glad to hear things are looking better.
leemilligan
Hi karl. Same problem again. This is getting silly now. Boost chanels showing blank screen. Internet is fine.
I've raised this to our network teams asking they look at the multicast transmissions for any errors etc.
