Error code ip6017
I'm trying to access my broadband channels but keep receiving error code ip6017 and the message that my i need to set up or add a tv boost. I have the kids boost and the entertainment boost but I am unable to watch either. Thanks
a oce should reply soon in a few days
A bite of info of Forum:
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:- Personal Profile > Personal Information
Hope that help Joe
Hi @Taranavsa
Have you tried blue button on remote > Settings > Software Information > Update software?
The other thing to try is go to "MORE TV" > My stuff and select something from one of your boost channels. This should force the system to search for your subscriptions.
If neither of these work, please report back and I will escalate this for you.
