Huawei TV plus box
ANSWERED
9 REPLIES 9
I seem to be unable to update the apps on my Huawei TV Plus box. I keep getting the message it can't be done and please try later - i try again later but still no luck. Also, when trying to use some apps I get a message saying that the box is no longer supported and I cannot use the apps. When reading through various threads it seems as though various boxes have had a major software update at some point as the screen shots of the tv pictures, such as the EPG, now look much different to my box. I guess that as my box isn't now supported then i don't recieve the software update?
Anyway, my question is that are there more modern tv plus boxes available now and if so can I have one please Smiley_Face
Many thanks
Martin
Which app is it that says it is no longer supported.
Hi, it's the Now TV app,
Martin
I'll get a different model box out to you.
Thanks Karl, thats great Smiley_Face
No Problem 🙂
Solution
Hi Karl,
The new box has arrived and the old one sent back. Everything is working fine now, many thanks for your help with this.
Martin
Hi Martin,
Glad I've been able to help.
I've got  Huawei tv box that only BBC Iplayer works on. No other player works and I just get the message "programme currently not available". I have had this problem for years but used other devices instead. I have recently upgraded to fibre and want to use the Huawei tv box more but this problem prevents me from doing so. Do you have any suggestions?
user5000
Hi User5000
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
