This evening I have lost all TV signals to my box. Having checked all connections, the only problem one us the aerial connection which is very loose and the connection in the box moves when I try to connect the aerial. I can get a signal if I hold the aerial in the port, but that's not really practical...
Is there any way the aerial connection port can be tightened, or do I need a new box? If so, how do I go about getting one?
I'll get the box replaced for you.
