No power light on powerline adapter
telonexpert
One of my four Talktalk powerline adapters is no longer showing any lights when plugged in and turned on. When I phoned the helpline I think I got through to a call centre in Botswana. I explained that the adapter was broken, showing no lights. For half an hour a trainee operator talked me though a completely inflexible script, often asking which lights were responding, and each time I replied “like I said, none of the lights work”. At the end she asked me to call back when she had an assistant, but I refused to be put off, and after another half hour of going over the same ground, I asked to speak to her supervisor. I was kept on hold for another 20 minutes before the supervisor came on, and within 10 minutes he booked me an engineer appointment. My big issue is with the inflexible script. If none of the lights work, the script should skip all the pairing and other synchronisation tests and go straight to the engineer bit. Shame on Talktalk for being such time wasters.
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
The forum is not real-time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & Bank Holidays). Alternatively, you can call the call centre or use online chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Otherwise, TT will not be able to tie up your forum username to your broadband account. Only you & TalkTalk have visibility of your details.
Hi telonexpert
Can you add your home phone number to your Community Profile so I can find your details.
