NowTV sky cinema boost
Newbie
Just subscribed to NowTV sky cinema, but when l go to the app and choose a film to watch l am asked to sign in.  I put in my email and password and it doesn’t recognise it.
can anyone help please.
You are using the same email and password as you used to sign up to NOW TV I take it?
Where and how did you initially create your account?
I used my PC but if you go to the NOW TV website on any device other than the TT box and sign in it will show your active passes. Once this is confirmed on there you shouldn't need to log in again. You can use up to 5 additional devices as well with up to 2 at the same time.
I have been a Now customer for years so I'm not sure about registering process on the box itself. The best way I have found is the NOW TV webpage from a mobile, tablet or PC. @ferguson  is well versed on doing this so follow his guidance if you can't access the webpage.
