Remote control faults
3 REPLIES 3
Several of the buttons on my remote control are no longer working properly.
They don't have any effect when pressed normally, and sometimes need to be pressed for a very long time and/or unfeasibly hard.
The 2 which are the worst, and which I would like to be able to use frequently are Guide and Mute.
(Vol+ and Vol- are ok.)
I have tried Mute on my TV's remote and it's fine.
(I also tried all of the obvious remedies, like changing the batteries, resetting the remote and the box etc.)
I've been putting up with going into the menu and selecting Guide that way, but it's not as good as having a working Guide button.
Other than carrying on and buying some thumb balm, would it be possible to have a replacement supplied please?
Thanks very much
demodulator
I'll get a replacement out to you.
Thank you Karl
D
No Problem 🙂
